After Update to 3.4 raster layers are not showing and other are transparent
2148
9
11-11-2024 03:08 AM
GottfriedKenda
This morning I worked with ArcGIS pro and all my projects where open normally and I was able to work on them. Then I installed the newest update and now I cant see most layers from my projects anymore. Also when i try to create a new projects layers are transparent or doesn't show up at all.
What is going on and how can i fix this?
DanPatterson
MVP Esteemed Contributor
right-click on a raster layer in the table of contents and select ... zoom to layer
Does it appear?
If so, then the raster needs a defined coordinate system
Define Projection (Data Management)—ArcGIS Pro | Documentation
... sort of retired...
GottfriedKenda
if i click on zoom to layer it is zooming to the extend but still not showing any raster layers. tried also to create new project just with data from living atlas and it is also not showing anything
DanPatterson
run the check on this page
ArcGIS Pro 3.4 system requirements—ArcGIS Pro | Documentation
and review your video (Directx etc) since the recommendations for video have changed
ShaneONeill_144
It would be worth trying a clean uninstall and reinstall of ArcGIS Pro
I've seen this fix many similar issues in the past
TammiDoyle
I'm having exactly the same issue. Currently uninstalling. I think this is a bug.
edited to add: reinstall did nothing. Now not even the base maps aren't displaying. I wonder if this is to do with new Windows 11 incompatabilities?
TimCoulombe_DES
I was having the same issue. Changing the Rendering Engine to DirectX12 from DirectX11 in Project-->Options-->Display fixed it.
TammiDoyle
Oooh Tim, you legend. How on earth you found that solution is beyond me, but it appears to have fixed the issue. Thanks for that!
KaraUtter2
I wish I had found your thread sooner! I already uninstalled the new version, reinstalled an older version, still had the issue, freaked out (only a little...). Thank you SO very much for this.
GottfriedKenda
Oh Tim thanks for this. I have reset my ArcGIS to the previous version because I was scared that I can't carry on with my work until your solution. Thanks
