Address Locator Producing Duplicate Results
2949
7
10-17-2024 01:45 PM
Roger_Schulz
I have been in the process of tweaking and improving the address locator for our city.
The Basic Locator has 2 Primary Role data sets. Address Points and Street Center Lines
I want Address Points to be the "primary" Primary role, and only fall back on street centerline data if a result does not match Address Points.
Currently, I am seeing multiple results because it is pulling from both simultaneously.
See the results below.
Is there a way to optimize these results?
The top result is Address Point the second is Street Centerline...
Thanks All
JoshKalovGIS
My understanding is that what you are looking for is how the multi role locators are supposed to operate.
From your image, it looks like the address points are missing city and state which the centerlines have. I wonder if that is causing the create locator tool to not see them as "identical" addresses and dedupe them.
DanPatterson
MVP Esteemed Contributor
I have never used it, but you seem to be describing a multirole locator
Combine multiple data layers into a single locator—ArcGIS Pro | Documentation
... sort of retired...
Roger_Schulz
This is correct it is a multi role locator. Not a classic composite locator.
Roger_Schulz
Following up.
I did look into the composite locator as it has more options for changing and setting the role order. Use A locator first than B Second if A has no results.
Is there a way to say If A has a successful result than don't give me the match from B at all? Rather than showing both as an option?
DanPatterson
not sure, but if it isn't in the interface or the python section, I suspect not
Roger_Schulz
what is the significance of "... sort of retired..."
JoshKalovGIS
Roger_Schulz
Boom that did it, awesome! Thanks!
