Adding svg as a line feature - Arc GIS Pro
2116
08-26-2021 02:15 AM
Kantoor__DataCount_-_Verkeerso
Is it possible to add a custom made .svg to Arc GIS Pro line feature. I made a custom arrow, which I want to add. I know it is possible when you are using point data, but I haven't seen the possibility when you use line data.
Side question: at the end I want to link the .svg to the data but I don't know if it is possible to maken graduated symbols of the .svg.
Kantoor__DataCount__Verkeerso_0-1629968493396.pngKantoor__DataCount__Verkeerso_0-1629968493396.png
David_Brooks
MVP Regular Contributor
You can add a marker symbol layer from SVG to appear at the end of the line.
In the Symbology > Settings tab, Add a marker symbol layer:
Then, in the Symbology > Layers tab, insert shape from File:
Add your SVG file and modify as required in the Marker Placement setting further down this tab.
With regard to scaling. You can scale proportionally, but I don't think you can link the marker symbol size to field atrributes in a graduated symbols way.
David
..Maps with no limits..
David_Brooks
@Kantoor__DataCount_-_Verkeerso , how did you get on with the solution?
David
