Adding non-numeric value to point feature
860
05-26-2022 08:47 AM
JacklynnCalvert
Per request, I am to add asterics to some point values on my map.  The "order" column is what is used to display and label the points.  When I try to edit say "23" to "*23", I get an error that says:  "The value you have entered is out of range or is not a whole number."  Is there any way to add the asteric to get it to display as one, clean point feature on the map?
DanPatterson
MVP Esteemed Contributor
You have to add a new text field then copy the values over as text to the new field, then edit those.
Eg pytthon in the field calculator
str(!YourNumberField!)
if you need all the numbers to have a * then
"*" + str(!YourNumberField!)
... sort of retired...
