Adding Missing Fonts
1227
05-31-2024 06:39 AM
SaratogaPLAN
ArcGIS PRO does not automatically include all fonts to the Resources\Fonts folder.  The solution is to add/copy the fonts into this folder.  Where do I get the fonts? Thanks.
MErikReedAugusta
MVP Regular Contributor
If you're asking where you find the fonts already installed on your computer, that depends on the operating system.
For Windows, it's generally <C:\Windows\Fonts>.  I don't know where it is for iOS or Linux.
I don't know that I've ever had a problem with ArcGIS Pro seeing the fonts I have installed there.  Are you running into problems with it not recognizing the fonts?
M Reed
"The pessimist may be right oftener than the optimist, but the optimist has more fun, and neither can stop the march of events anyhow." — Lazarus Long, in Time Enough for Love, by Robert A. Heinlein
If this post or another helped you out, please consider giving the post(s) a Kudo or marking them as the Solution. ESRI Staff use both of these features to help keep track of posts on these forums.
