Adding data to the Feature Layer at the hosted
1490
01-26-2024 08:43 AM
Murtaza_Mir
Hi all,
I am trying to update the data at the hosted layer. I am using Python programming language and in addition to that, I am also experimenting with different packages like arcgis, requests, json, etc. Below is the response that I get after adding a record at the hosted layer:
[{'success': True, 'globalId': '<globalid>', 'objectId': <objectId>}]
As it can be observed that the success is "True". However, even then, I don't see the data getting added at the hosted feature layer. Is there anything that I am missing? This is my first data engineering related project in ArcGIS. I am not able to figure out what am I missing. I utilized various methods, but I get the exact same result.  Please let me know what your thoughts are. I will also post my code below.
Thank you
fc = r'path_to_data\abc.sde\table'
fields = ['*']
data = [row for row in arcpy.da.SearchCursor(fc, fields)]
columns = [field.name for field in arcpy.ListFields(fc) if field.name in fields or fields == ['*']]
df_sde = pd.DataFrame(data, columns = columns)
# Creating a GIS instance
gis = GIS('<gis_portal>', username, password)
service = '<service_layer>'
hosted = '<hosted_layer>'
# Connecting to the services
fabric_service = FeatureLayerCollection(service, gis)
fabric_hosted = FeatureLayerCollection(hosted, gis)
service_layer = fabric_service.layers[num1]
hosted_layer = fabric_hosted.layers[num2]
## Importing the records as dataframe
service_records = service_layer.query(where="<some condition>", as_df=True, return_geometry=True)
## Truncating all the data in the hosted layer
try:
    logging.info("Starting data truncation process for the hosted layer.")
    result = hosted_layer.delete_features(where="1=1")
    if result['deleteResults']:
        logging.info("Data truncated successfully.")
    else:
        logging.warning("No data was deleted.")
except Exception as e:
    logging.error("Error occurred while truncating data: " + str(e))
## Importing the hosted layer data just to get the column names and schema. It results in an empty dataframe with column names and corresponding to data types
hosted_records = hosted_layer.query(where="1=1", as_df=True, return_geometry=True)
# Function to modify geometries of the geometry column in sevice_records to match the geometry requirement in the hosted
def project_in_batches(geometries, in_sr, out_sr, batch_size=5000):
    projected_geometries = []
    for i in range(0, len(geometries), batch_size):
        batch = geometries[i:i + batch_size]
        projected_batch = project(geometries=batch, in_sr=in_sr, out_sr=out_sr)
        projected_geometries.extend(projected_batch)
    return projected_geometries
# Reproject the geometries from service layer to match the hosted layer's spatial reference in batches
projected_geometries = project_in_batches(geometries=service_records[<geometry_column>].tolist(),
                                          in_sr={'wkid':wkid1},
                                          out_sr={'wkid':wkid2})
# Replace the original geometries with the projected ones
service_records[<geometry_column>] = projected_geometries
def merging_service_sde():
    This function acts as introducing the columns that must be present in the hosted layer but don't have a corresponding column neither in service_records nor df_sde. After that, such columns are populatied by Null values for the time being.
    cols_service = [<columns in service_records>]
    cols_sde = [<columns in df_sde>]
    cols_ignore = [<columns in hosted_records that do not have a corresponding column neither in service_records nor in df_sde>]
    temp_df_record = pd.merge(service_records[cols_service], df_sde[cols_sde],
                              how = 'left', left_on = col1, right_on = col2)
    # Setting columns in cols_ignore as Null
    for col in cols_ignore:
        temp_df_record[col] = pd.NA
    return temp_df_record
merged = merging_service_sde()
mapping = {<mapping dictionary that maps the column names in such a way that it is identical to the column names present in hosted_records>}
# Mapping the column names
merged = merged.rename(columns = mapping)
# Extra step to align the columna according to the order in hosted_records for better readability
merged = merged[hosted_records.columns]
# Aligning the data types
for column in merged.columns:
    if column in hosted_records.columns:
        desired_type = hosted_records[column].dtype
        merged[column] = merged[column].astype(desired_type)
## Handling the missing values
object_cols = merged.select_dtypes(include = ['object', 'string']).columns
num_cols = merged.select_dtypes(include = ['float64', 'Float64', 'Int32', 'Int64']).columns
date_cols = merged.select_dtypes(include = ['datetime64[ns]']).columns
merged[object_cols] = merged[object_cols].fillna('N')
merged[num_cols] = merged[num_cols].fillna(0)
merged[date_cols] = merged[date_cols].fillna('2000-01-01')
merged_spatial = merged.spatial.to_featureset()
batch_size = 100
total_records = len(merged_spatial.features)
batches = [merged_spatial.features[i:i + batch_size] for i in range(0, total_records, batch_size)]
for i, batch in enumerate(batches):
    try:
        batch_feature_set = FeatureSet(features=batch, geometry_type=merged_spatial.geometry_type,
                                       spatial_reference=merged_spatial.spatial_reference)
        update_result = hosted_layer.edit_features(adds=batch_feature_set)
        success = list(set([i['success'] for i in update_result['addResults']]))
        if len(success) == 1 and success[0] == True:
            logging.info(f"Batch {i+1}/{len(batches)} added successfully")
        else:
            logging.info(f"Batch {i+1}/{len(batches)} not added")
        logging.error(f"Error adding batch {i+1}/{len(batches)}: {e}")
Murtaza_Mir
It finally worked. The issue was caused by the geometry column that was getting altered when I was merging two datasets in Pandas. This modification in the geometry column was preventing the data from getting uploaded at the hosted.
Murtaza_Mir
