Add selected area to another layer
4118
02-11-2022 12:13 AM
DavidMrázek
Hello,
does anyone know what function you can use to add selected faces to another existing layer? Areas were selected via Select Layer By Location.
Thank you
David
DanPatterson
MVP Esteemed Contributor
Save the selection to a featureclass, then append or merge it to the destination featureclass, in order to provide the necessary field types checks
Append (Data Management)—ArcGIS Pro | Documentation
or
Merge (Data Management)—ArcGIS Pro | Documentation
append to an existing file or use merge to create a new one.
Try not to do a shortcut on the process in order to maintain the attribute integrity
... sort of retired...
DavidMrázek
Thanks for the reply.
How do I create a FeatureClass from a selected Feature?
ASw93
If you right click the layer that you've selected features from, you can go to Selection > Make Layer from Selected Features.
DavidMrázek
And somehow programmatically?
DanPatterson
selections are honored, use
Make Feature Layer (Data Management)—ArcGIS Pro | Documentation
see the code examples in the python tab
