Add-In tab missing from ArcGIS Pro
4254
6
07-15-2022 12:26 PM
RandyKreuziger1
Just downloaded and installed ArcGIS Pro 3.0 on a new VM that has never had Pro on it before.  The  Add-In tab is missing.  A couple years ago I had this happen on a Pro install but I can't remember what I had to do to fix it.
DanPatterson
MVP Esteemed Contributor
I don't use any, but guessing that you need to access them through the Project backstage in the AddIn section
... sort of retired...
RandyKreuziger1
Dan, I forgo to mention that I have already  added a folder through the Add-In Manager so that's not it.
RandyKreuziger1
When I restarted Pro I get a message in the Add-In Manager that may explain things.
"This  add-in cannot be loaded because it targets an incompatible version of ArcGIS Pro.  Current version: 3.0  Add-in targets: 2.5"
Tags (1)
RandyKreuziger1
Nope, I now have an Add-In recompiled for 3.0 and have added the folder.  Stopped and restarted Pro and still no Add-In tab.
mody_buchbinder
I think it is created just when you have an AddIn that uses it.
You do not see it if its empty.
DanPatterson
Tech Support would be best at this stage
