Add Folder in Catalog pane starts, but crashes ArcGIS Pro while loading.
3154
20
02-28-2022 10:45 AM
RalphAnhold1
New install of ArcGIS Pro, Windows 11.  Start project with blank template.  Want to add existing folder, so in Catalog pane/folders, I right-click, select AddFolder.  UI pane starts, but update stops and Error reporting tool pops up.  No recovery.  It 'appears' that I can't use existing data.
Hints on how to fix?
RalphAnhold1
It is when ArcGIS Pro attemptes to open a file dialog.  I just launched, and instead of starting with a new blank project, I attempted to open a previous project.  As soon as the file dialog popped up, crash, error report tool.
-r
ABishop
It doesn't return any error numbers or anything?
Amanda Bishop, GISP
RalphAnhold1
yep
ABishop
Just found this thread that led to a bug at 2.8?  Read thread here: https://community.esri.com/t5/arcgis-pro-questions/network-error/td-p/1065771
Amanda Bishop, GISP
RalphAnhold1
Anytime the dialog box comes up to interact with PC filesystem.  I decided to capture a screenshot.  The suggested workaround did work, so I went to look at settings if default paths were part of it.  As soon as I hit the folder icon, bang.
-r
RalphAnhold1
Just did the 'open other project' again and submitted the error report.  I did not see an error number
DanPatterson
MVP Esteemed Contributor
blank template
went to catalog, clicked on folders and there was a default one based on my profile on my local machine
Did you get this far? is there any default folder?
... sort of retired...
RalphAnhold1
yes, but when I right-click on Folders, select Add Folder Connection, the filesystem dialog pops up, and error reporting.
this is a tough nut to crack, eh?
DanPatterson
You have a bad install.  You will need to completely uninstall Pro, rename any esri folders in the c:\users\"you"\apps..., and perhaps rename any registry entries as well.  If you have 3rd party software that depends on Pro, it will have to be removed first.
OR
contact Tech Support
RalphAnhold1
I tried uninstall, delete/rename esri folders, arcgis folders. Ccleaner dump of unused reg entries. Reboot/reinstall/update. Same result. May need Windows reinstall.
