Add control handles (Bezier curve adjustment 'arms') to vertices?
1993
04-05-2022 10:45 AM
wayfaringrob
Honored Contributor
I've reviewed the documentation below but cannot figure out a way to simply add control handles to an existing vertex - those blue things you use to adjust the way the line curves:
I'm working with annotation and trying to correct the curvature of some road labels, so my options in terms of editing tools are limited. I could replace the entire geometry and use some of the curve tools there, but I'm really just looking to add the handles to existing points rather than redraw the whole thing. Something similar to this tool in Illustrator would be great, does it exist in Pro?
https://pro.arcgis.com/en/pro-app/latest/help/editing/modify-feature-segments.htm
https://pro.arcgis.com/en/pro-app/latest/help/editing/modify-feature-vertices.htm
https://pro.arcgis.com/en/pro-app/latest/help/editing/create-bezier-curves.htm
RhettZufelt
MVP Notable Contributor
If I select the annotation, then Edit Vertices, I see the line(s) displayed.
Then, if I right click on a section of the line and change to (or insure is set to) Circular Arc, then I can just grab the section of the line and modify the curve.
Can also add vertices anywhere along that line if you need to modify the curve even more.  So, it behaves the same, even though the "handles" aren't there.
R_
RhettZufelt
R_
wayfaringrob
Honored Contributor
Ahhhh, I was not thinking to R click the segment. "To Bezier Curve" is exactly what I needed, thanks!
