Add a geocoded point to a feature class, Feature Class not showing up
1035
05-21-2025 12:28 PM
Labels (2)
Robin
I am trying to add locations I am searching through the Locate feature. And add them to a feature class. However, when I click "Add to Feature Class" my feature class doesn't show up in the menu. Any ideas why?
I am following this process https://pro.arcgis.com/en/pro-app/latest/help/data/geocoding/add-geocoded-point-to-an-existing-featu...
I tried creating a new shapefile and it still won't show up in the menu. I added a coordinate system to the shapefile.
RyanUthoff
MVP Regular Contributor
Is your shapefile or feature class that you want to add locations to in your map? They need to be in the map in order for them to show up in the menu when you click Add to Feature Class.
ShanaBritt
@Robin Have you tried with a feature class in a file gdb? What locator are you using to search for places in the Locate pane? What happens at Step 4 if you select 'Create new feature class` that is in a file gdb.
