Adapting Annotation Workflow to Pro - Label Offset
818
05-25-2023 11:34 AM
Henry
I'm attempting to adapt some of my organization's workflow from Map to Pro-based workflows. One that I'm hung up on is an annotation workflow. For the most part, it works the same besides some small parameters changes to make.
1) New point feature records are generated. Label features.
2) Select those new features, convert labels to annotation.
3) Copy new annotation features, paste into production dataset
4) Format copied annotation attributes < In ArcMap, after I adjusted the Annotation symbol to one of our smaller preconfigured symbols, the pasted annotation would remain centered on the point features. However, in Pro after adjusting the symbol, the annotation for all the copied features renders with a significant offset.
Is there some method with which I could adjust the pasted annotation features' anchor point or ability to snap so that when the annotation symbol is changed the center of the annotation remains snapped to the center of the feature that is posted on. I know if I select and move the annotation features individually they will snap, but I'm trying to do this in bulk so I don't have to go record by record.
Thank you!
Henry
