Accessing sample data in Arcade Playground
2278
02-04-2021 09:01 AM
JoeBorgione
@XanderBakker -  in an early post regarding attribute rules  you mention:
Using the playground is great to check functions and logic, but you won't have access to your data and the sample data provided is very limited (2 polygon layers).
How does one access the sample data to test an attribute rule's logic?
That should just about do it....
jcarlson
Switch the Profile, and the layers / functions available will update accordingly.
Attribute Rule Calculation, for instance, has two layers in the $datastore object.
- Josh Carlson
Kendall County GIS
jcarlson
- Josh Carlson
Kendall County GIS
JoeBorgione
Awesome. Thanks!
