3D-Polygon: Edit features -> Add vertex does not interpolate Z, Z of new vertex is 0m
1604
11-09-2021 03:27 AM
FedericoFossatti86
Hello,
I am running ArcGIS Pro 2.8.3.
I need to densify some 3D polygons by adding a vertex to segments that are longer than 50 m.
The problem is that when I add the vertex with Edit Vertices -> Add vertex, the newly created vertex will be at z = 0 m. I want it to be interpolated using the Z of the nearest vertices. I believe this is the intended behaviour of ESRI:
This is my original polygon (the format is shapefile by the way):
I want to add a vertex here:
And I get the vertex with z = 0m, instead of an interpolation of its neighbours:
Any clues?
MarianneLindauLanghelle
I have the same problem trying to add vertices with interpolated z-values to a polyline. Is there a setting I'm missing?
jchester73
I am also wondering this.
