2 + Mapframe dynanic text
719
07-03-2019 08:38 AM
MarcelSt-Germain
Hi  hope someone could help me.
In a map layout I have 2 or 3 maps (map frame).
I link each one to a specific view like map1 = view1, map2 = view2…
So, since map series is limited to the layout not for each map, I can’t use it when I have more than a map in a layout.  Hope ESRI will add this to a future release.  The map series is important for the map, not the layout but… Esri doesn’t think or that.
I’m trying to dynamiquely link info to each Map.  I try to use maps frame syntax with each map and make a query to have only one entry in my reference polygon before applying zooms to this unique polygon.
I check the examples and think it was the following script the most adapted but something is wrong because the result is the same for each map.
declination
- <dyn type="mapFrame" name="portrait gauche Map Frame" property="magneticDeclination" units="ddm" decimalPlaces="0" showDirections="yes"/>
page ( from the table field )
- <dyn type="page"  mapFrame="portrait gauche Map Frame"  property="attribute" field="carte"/>
