Minor annoying Problem in Pro publishing to server
2760
7
07-02-2019 10:45 AM
ThomasColson
I'm so happy that https://community.esri.com/ideas/12258-arcgis-pro-publish-services-to-arcgis-server is fully implemented I'm probably not going to log a case on this, but this is somewhat annoying. When publish to any of my servers that have the letter "D" in the web adapter name, the URL of the service returned to Pro is wrong. These are all 10.6.1 unfederated servers. This makes "Manage the Map Service" at the end of publishing somewhat difficult.
Note the "d" missing:
missing "md" here:
Same in SharingInfo.json
Is anyone else seeing this? Were you able to figure out an easy fix? Wondering if it's related to how I'm naming my server connection?
SusanTran
Hi Thomas,
I am able to reproduce the issue and we are looking into it. It seems to occur when you include 'admin' at the end of your server URL in the dialog where you made the server connection. As a workaround, make a new server connection, entering your server URL as "https://server.domain.com/webadaptor' without 'admin'.
Thanks.
RobertBorchert
Honored Contributor
shouldn't your address include a :6443 or some such in the address.  and should you be publishing to your Rest services directly.  We have our not visible.
ThomasColson
We have CA-signed certs on both the server and the webadapter, so adding the port is not required. Not clear about publishing rest services directly? Is there another way to publish services? We control access to the rest endpoints with Active Directory.
RobertBorchert
Honored Contributor
We don't have our rest visible.  when we publish from pro or arcmap we publish to a string similar to this
https://maps.mycompany.com:6443/arcgis
the rds is the other option.
Our rest is hidden.  Though it really should not make a difference.
This is odd. I asked couple other guys here. We have dozens of services spun up with D's in them
ThomasColson
ahhh. I have quite a few GIS servers, so it's something like
https://maps.mycompany.com/server1
https://maps.mycompany.com/server2
https://maps.mycompany.com/server....
https://maps.mycompany.com/server10
RobertBorchert
Honored Contributor
it looks like your publishing from Pro.
Have you tried going into managing your portals and logging in to the portal using a normal log in and not the rest.
though you really got me, it should not be truncating the d
my log into our portal used in the example is simply
https://maps.mycompany.com/arcgis
good luck
SusanTran
Hi Thomas,
Thanks.
ThomasColson
Unfortunately, when using right-click -> properties to convert a sever connection to "Publisher" (introduced in 2.3) for the purpose of publishing services, "admin" is what you get. As said, this is a minor annoyance and in no way blocks any critical functionality, glad you could repro it.
