When copy / pasting text objects between two layouts keep location the same ****Almost Fixed in 3.3.1 **
1949
11
06-06-2024 05:39 PM
Status: Already Offered
RTPL_AU
Honored Contributor
Parity with ArcMap request.
Currently in Pro, when you copy text from one layout and paste it into another, it is moved to an arbitrary offset to the bottom right of the original.
In ArcMap when copy/pasting between two layouts the pasted text is placed in the original location.
Update the behaviour in Pro to replicate ArcMap.
Edit:
I've just noticed that if you copy/paste between layouts that have the ruler set to different units, then the pasted object is placed in the numerical position value and not the correct location on the page. Non-text objects are scaled by the unit factor as well.
Expected behaviour is to place objects in same position on page at the same size. (this is what other apps I use do....)
11 Comments
nicolemnovak4
It's happening to me when I'm using remote desktop.
