Tessellate by Mask instead of only Extent
1611
05-07-2019 09:53 AM
Status: Open
EricEagle
I rely heavily on tessellation to aggregate and summarize extremely dense point content.  Currently the only limiting environmental variable the GenerateTessellation_management() method uses is Extent.  This is inefficient as I demonstrate in the simplified graphic above.  In this case, I would spend loads of time building cells over an extent, the majority of which has no data, and that will be discarded later anyway.
I would like for the Generate Tessellation tool to support not only Extent, but Mask (vector polygon) to build cells.
3 Comments
DougEberly
Yes, please! I’m working with global data and tessellations only by a mask (polygon) is a Must!
For example, I’m trying to develop a 10,000 sq meter tessellation from the shoreline out 1 mile for all US States (Conus, AK, HI, Puerto Rico and Guam). The extent results in a tessellation where the size is 35 billion with a B features. When in reality I only need less and 1% the extent with this size grid.
Help?! My computer is sitting at 0% complete in the progress bar now for over 1 hour.
@EricEagle , any luck since your post a couple years ago?
EricEagle
Hi Doug,
Unfortunately, no.  I haven't heard anything from Esri on it.  Probably what I should do is send this up via my Esri customer rep and get it put in as an enhancement request.  I seem to have better luck that way.  It is unclear how Esri harvests and approves ideas from these boards.  Sometimes I'll see an idea with 2 votes "under review" and sometimes even implemented, while other ideas with dozens of votes go completely unaddressed.
KoryKramer
@EricEagle Re: "It is unclear how Esri harvests and approves ideas from these boards."
See https://community.esri.com/t5/community-help-documents/frequently-asked-questions-about-arcgis-ideas...
