Table Frames that cover multiple pages
3083
7
11-02-2021 10:50 AM
Status: Open
MichaelMorgan4
I would like to produce a table frame in Arc Pro layouts that can traverse multiple pages in a layout if it overflows ([...]) the layout page it is initially set on. This could be accomplished using a setting in the Table Properties -> Arrangement -> Fitting Strategy area, or possibly a "Continue Table Frame" button in the Insert menu. This would work well for our variance notification list, which can extend to a couple hundred parcels, for which I would need to list owners for our planning department.
7 Comments
AubriOtis
Hi! It seems like this is a scenario for a report, instead of a table frame on a layout. Reports can span multiple pages, include maps, and are great ways to dive into data. Does a report fit your needs?
MichaelMorgan4
I will try reporting when the situation comes up again. Thank you for the suggestion.
wayfaringrob
Reports, IMO, are terribly inconvenient, buggy, feature-poor, and not quite the same as a layout. I'd like to see threaded table frames as well.
JamesBooth
Any updates or developments on table frames? I really need to figure out how to have my table frame on multiple 8.5 x 11" pages. If there is no room on one page, then I would like it to continue on using a second page and so on. Any ideas out there on how to make this possible?
AubriOtis
Status changed to: Open
RyanBohan
How is it not possible to easily split a Table Frame across multiple maps, similar to a map series?
To fit the table I needed to display, I had to use a size 8 font. I wish there was a way to split the table after 20 elements onto another map layout, similar to a map series.
AubriOtis
@RyanBohan have you tried a report? From your picture it looks like that might work for this layout while this idea is still being considered.
