Support Non-Interactive Authentication for ArcGIS Pro in Batch Processing Environments
601
9
07-07-2026 01:17 PM
Status: Closed
MelanieWawryk
Enable Non-Interactive ArcGIS Pro Authentication for Service Accounts and Automated Workflows
As more organizations are forced to move from Concurrent Use and Single Use licensing to Named User licensing, there is a growing need for a supported method to run ArcGIS Pro-dependent automation without requiring an interactive user session.
Many enterprise GIS environments rely on:
  • Scheduled ArcPy scripts
  • FME Form automated workflows
  • Windows Task Scheduler jobs
  • Enterprise ETL processes
  • Overnight geoprocessing tasks
  • Data synchronization and maintenance jobs
Today, these workflows often depend on ArcGIS Pro being previously opened and signed in by a user. Organizations have reported situations where automated processes fail until ArcGIS Pro is launched interactively and the Named User license is refreshed. [support.esri.com], [support.safe.com]
The current model creates challenges for:
  • Servers located in data centers
  • Service accounts with interactive logon disabled
  • Cybersecurity policies that prohibit user logins on servers
  • High availability and disaster recovery environments
  • FME and Python batch processing platforms
Suggested Enhancement
Provide a supported mechanism that allows ArcGIS Pro licensing and authentication to operate in a fully unattended manner.
Possible approaches could include:
  • Service Principal authentication
  • Application identities
  • Managed Service Account (gMSA) support
  • OAuth client credentials flow
  • Command-line licensing/authentication tools
  • Named User token refresh APIs
  • Machine-based licensing for automation workloads
  • Headless ArcGIS Pro authentication
For example: arcgispro.exe /signin service_account or proauth.exe --login service_account or an API that allows a scheduled process to securely refresh authentication without launching the ArcGIS Pro user interface.
Many organizations use ArcGIS Pro as a dependency for:
  • FME Esri Geodatabase readers/writers
  • ArcPy automation
  • Enterprise geodatabase maintenance
  • Data replication
  • Nightly GIS processing
  • Asset management integrations
Without a supported unattended authentication mechanism, organizations risk:
  • Failed overnight jobs
  • Manual intervention by GIS administrators
  • Reduced reliability of enterprise automation
  • Increased operational costs
  • Barriers to adopting Named User licensing
Benefits
A supported non-interactive licensing model would:
  • Improve reliability of enterprise automation
  • Support modern DevOps and server environments
  • Eliminate the need to periodically open ArcGIS Pro
  • Enable secure service account usage
  • Simplify migration away from Concurrent Use licensing
  • Improve support for FME, Python, Task Scheduler, and enterprise ETL platforms
As ArcGIS Pro becomes the primary desktop GIS platform and Concurrent Use licensing is phased out, unattended processing should be a first-class and supported deployment scenario for enterprise organizations.
9 Comments
ValeriaChavez
Status changed to: Closed
Hi @MelanieWawryk
I will be closing this thread as what you're describing here is a violation of the licensing agreement.
ArcGIS Pro allows users to sign-in across multiple machines to reduce friction when switching devices or forgetting to sign out after each session. For example, if someone is still signed in on their work laptop and needs to sign in elsewhere, that convenience is within the intent of the policy.
Using a single user type to actively run ArcGIS Pro in parallel on multiple machines (e.g., virtual desktop running a ModelBuilder job while the same user edits data on a laptop) is not permitted, nor is using ArcGIS Pro for automated background tasks.
If you and your organization require running workflows in parallel or as nightly scheduled tasks, I encourage you to get in touch with your account team to explore alternative ways to license ArcGIS capabilities such as ArcGIS Server via ArcGIS Enterprise.
Thank you for being an active member of Esri Community!
MelanieWawryk
How do you expect people to run geoprocessing scripts overnight? We have been scripting jobs for the last 25 years and now they all fail because ArcPro isn't signed in?
JoshKalov
@ValeriaChavez That is a confusing response to say that Pro can't be used to run nightly scheduled tasks. That has been a standard part of the ESRI Desktop world since ArcMap. ESRI even built a whole UI in Pro to make it easier to do! Schedule geoprocessing tools | ArcGIS Pro documentation
Please reopen this idea.
BillFox
why kill the idea?
isn't that what the ideas place if for? to ask/answer/suggest/work-rounds, etc.?
would something like this official esri support knowledge base article help?
Running scheduled Python task under a group managed service account throws an ArcGIS Pro License err...
MelanieWawryk
We have a separate ArcPro license for the service account, so I don't see how it is breaking the license as @ValeriaChavez  states. Thanks @Bill I will try the work around. I have also put it into Esri support. I think that solution might have worked when you could still have a stand-alone license. I will report back once we test. Thanks
MelanieWawryk
So far, the feedback from Esri has been disappointing. The guidance we've received suggests that organizations wanting to run unattended ArcPy scripts in a supported manner should use the ArcGIS Server Python environment. In practical terms, that appears to mean deploying ArcGIS Server wherever those scheduled scripts need to run, which could require the purchase of additional ArcGIS Server licensing plus ongoing annual maintenance.
For organizations that have been successfully running automated geoprocessing workflows for many years under existing licensing, this feels like a significant increase in cost and complexity for no additional business value. What was previously a straightforward automation workflow now appears to require infrastructure and licensing that can be an order of magnitude more expensive.
It's hard not to view this as a licensing decision rather than a technical necessity. I hope Esri reconsiders its position and provides a supported non-interactive authentication model for ArcGIS Pro that allows customers to continue automating their workflows without being forced into substantially more expensive server-based deployments.
RyanDavis3
I can't believe this suggestion has been "closed". A customer posts a very real business need, and the response is "go talk to a different product team". No helpful links or anything.
Billrichter
@ValeriaChavez We have the same issue.  We are trying to move away from ESRI License Manager and use AGOL license but it is causing issues running scripts. Is there a solution recommended by ESRI for scripts that rely on having an ESRI license?  Or could this issue be escalated?
MelanieWawryk
Thank you to everyone that continues to post on this topic, I think Esri forgot that these are valid workflows that many of their customers have used for 25+ years and didn't consider it when implementing named users.
We are still waiting to see why the single use license (One per geoprocessing machine) won't work, it seems like it was made just for this type of scenario. We will return the single use license for now and just use an AGOL one.
For now, we have created a separate creator license in AGOL for each geoprocessing machine. We log in to it using AGOL and then Authorize to use ArcGIS Offline for as many days as our ELA licensing ends. We are not sure yet if this will work or if we will need to further run the scheduled tasks as a local user with the same name as the AGOL user or perhaps have to create a windows account with a matching name to make it work. Will report back once we have tested more but hopefully it is enough for people to get their scripts back up and running.
From Esri:
To authorize Python outside of ArcGIS Pro, one of the conditions listed in the documentation below must be met:
https://pro.arcgis.com/en/pro-app/3.5/arcpy/get-started/installing-python-for-arcgis-pro.htm#ESRI_SE...
These two conditions are most relevant to your situation:
- Sign me in automatically is checked when signing in to ArcGIS Pro.
- ArcGIS Pro has been authorized to work offline.
You can find the option to authorize ArcGIS Pro to work offline in the Licensing tab within Pro (see the highlighted bit below):
The Licensing tab is also the location that allows you to switch between the Single Use or the Named User license as the license, you're actively using to authorize the application.
These options should help ensure that ArcGIS Pro does not prompt for credentials each time it is launched on the machine.
