As more organizations are forced to move from Concurrent Use and Single Use licensing to Named User licensing, there is a growing need for a supported method to run ArcGIS Pro-dependent automation without requiring an interactive user session.
Many enterprise GIS environments rely on:
Today, these workflows often depend on ArcGIS Pro being previously opened and signed in by a user. Organizations have reported situations where automated processes fail until ArcGIS Pro is launched interactively and the Named User license is refreshed. [support.esri.com], [support.safe.com]
The current model creates challenges for:
Provide a supported mechanism that allows ArcGIS Pro licensing and authentication to operate in a fully unattended manner.
Possible approaches could include:
For example: arcgispro.exe /signin service_account or proauth.exe --login service_account or an API that allows a scheduled process to securely refresh authentication without launching the ArcGIS Pro user interface.
Many organizations use ArcGIS Pro as a dependency for:
Without a supported unattended authentication mechanism, organizations risk:
A supported non-interactive licensing model would:
As ArcGIS Pro becomes the primary desktop GIS platform and Concurrent Use licensing is phased out, unattended processing should be a first-class and supported deployment scenario for enterprise organizations.
Hi @MelanieWawryk,
I will be closing this thread as what you're describing here is a violation of the licensing agreement.
ArcGIS Pro allows users to sign-in across multiple machines to reduce friction when switching devices or forgetting to sign out after each session. For example, if someone is still signed in on their work laptop and needs to sign in elsewhere, that convenience is within the intent of the policy.
Using a single user type to actively run ArcGIS Pro in parallel on multiple machines (e.g., virtual desktop running a ModelBuilder job while the same user edits data on a laptop) is not permitted, nor is using ArcGIS Pro for automated background tasks.
If you and your organization require running workflows in parallel or as nightly scheduled tasks, I encourage you to get in touch with your account team to explore alternative ways to license ArcGIS capabilities such as ArcGIS Server via ArcGIS Enterprise.
Thank you for being an active member of Esri Community!
How do you expect people to run geoprocessing scripts overnight? We have been scripting jobs for the last 25 years and now they all fail because ArcPro isn't signed in?
@ValeriaChavez That is a confusing response to say that Pro can't be used to run nightly scheduled tasks. That has been a standard part of the ESRI Desktop world since ArcMap. ESRI even built a whole UI in Pro to make it easier to do! Schedule geoprocessing tools | ArcGIS Pro documentation
Please reopen this idea.
why kill the idea?
isn't that what the ideas place if for? to ask/answer/suggest/work-rounds, etc.?
would something like this official esri support knowledge base article help?
We have a separate ArcPro license for the service account, so I don't see how it is breaking the license as @ValeriaChavez states. Thanks @Bill I will try the work around. I have also put it into Esri support. I think that solution might have worked when you could still have a stand-alone license. I will report back once we test. Thanks
So far, the feedback from Esri has been disappointing. The guidance we've received suggests that organizations wanting to run unattended ArcPy scripts in a supported manner should use the ArcGIS Server Python environment. In practical terms, that appears to mean deploying ArcGIS Server wherever those scheduled scripts need to run, which could require the purchase of additional ArcGIS Server licensing plus ongoing annual maintenance.
For organizations that have been successfully running automated geoprocessing workflows for many years under existing licensing, this feels like a significant increase in cost and complexity for no additional business value. What was previously a straightforward automation workflow now appears to require infrastructure and licensing that can be an order of magnitude more expensive.
It's hard not to view this as a licensing decision rather than a technical necessity. I hope Esri reconsiders its position and provides a supported non-interactive authentication model for ArcGIS Pro that allows customers to continue automating their workflows without being forced into substantially more expensive server-based deployments.
I can't believe this suggestion has been "closed". A customer posts a very real business need, and the response is "go talk to a different product team". No helpful links or anything.
@ValeriaChavez We have the same issue. We are trying to move away from ESRI License Manager and use AGOL license but it is causing issues running scripts. Is there a solution recommended by ESRI for scripts that rely on having an ESRI license? Or could this issue be escalated?
