Streamline Domain Name and Description Creation
1129
03-26-2015 05:59 AM
Status: Closed
AndrewRuth
At this point, you have two options for creating domain names and their associated description.
  1. You can manually enter the domain name and descriptions into the Domains tab of the geodatabase properties window.
  2. You can utilize the "Table to Domain" tool to import one domain value, coded values, and description at a time.
Issues with Method 1: There is room for error when manually entering the domain name. This could lead to the domain name not matching the  attribute table field name.
Issues with Method 2: Though this would address the "entry error' issue above in Method 1, you can only import one domain name at a time and you still have to utilize a "middle man", i.e. the  Table to Domain tool.
My suggestion: Utilize the Geodatabase Properties window and Domains tab, but instead of manually entering the Domain Name and Description, have a method by which the empty domain name cells would link directly to the attribute table field names choices and have the description fill in directly from the associated metadata (if completed).
Since this would be linked to the attribute table, you could also automate the entry for field type under domain properties so that it would choose either text, double, float, date, etc...automatically. This also would help prevent errors and save time on the back end.
Andy
2 Comments
by Anonymous User
Importing from Excel or csv might be nice too.
SSWoodward
Status changed to: Closed
This idea has been closed as a duplicate of the Data Management Idea linked below. Don't worry, you can still show your support by commenting and adding kudos to the open idea. Thanks for your contributions!
Link to open, duplicate Idea.
