Selection layer using standalone table
373
01-17-2024 01:29 PM
Status: Under Consideration
Bud
Honored Contributor
ArcGIS Pro 3.2.1
I can make a selection layer from a feature class:
But I don't seem to have that option for a non-spatial table:
Could the option to Make Layer From Selected Features be added for non-spatial tables?
4 Comments
TanuHoque
hi @Bud
I'm curious to know your use cases. I'd appreciate if you could provide one.
Thanks
Bud
@TanuHoque
If I encounter data integrity issues in non-spatial GDB tables, I'll email the details to the person responsible. Ideally, I'd manually select the problem rows in the attribute table, create a selection layer, and save it as a .LYRX. And include the .LYRX in the email. It would be a way for the person to navigate the records easily and edit them.
The perfect solution would be to convert a selection to a definition query, such as ASSET_ID IN (1,2,3), using OOTB functionality. That would be more robust, but no OOTB tool exists for that. I find using Python as a workaround to be clunky.
So alternatively I want to create a selection layer and share it as a .LYRX.
TanuHoque
Thanks @Bud very much for sharing your workflow. That is very helpful.
TanuHoque
The perfect solution would be to convert a selection to a definition query (such as ASSET_ID IN (1,2,3) using OOTB functionality.
@Bud probably you are aware of this idea which is under consideration.
https://community.esri.com/t5/arcgis-pro-ideas/selection-to-definition-query/idi-p/932030
