Return to first extent
567
01-06-2016 03:00 AM
Status: Open
RobMillman1
it's great we have the ability to go back to previous extent in desktop but there are often times (when georeferencing for example) when you want to go back to the original extent.  As the list obviously exists in that you can go back through them incrementally you should be able to jump to the start of the list
2 Comments
DuncanHornby
Why not simply create a bookmark, it takes a couple of seconds to create?
MikeLouwrens
You can set your 'Full Extent' in the Data Fram Properties > Data Frame tab > Extent Used By Full Extent Command.  Once this is set you can just use the 'Full Extent' button on the standard Tools Toolbar (the one with Pan, Zoom, Next/Previous extent buttons).
