Reset Default Field Order in Pro
2576
07-20-2020 10:25 AM
Status: Implemented
mpboyle
Honored Contributor
In ArcMap there is an option within the Fields view to reset the default field order.  I believe it would be nice to have the same functionality within Pro.
3 Comments
RobertBorchert
Quite agreed. I often find myself making changes to field order, alias, etc only to decide it isn't going to work the way I want.  And rather then re-adding a feature and having to re-work labels and symbols it would be nice to simply reset to defaults.
KyleC
by Esri Contributor
In the attribute table's menu Menu, there is a 'Reset Field Order' button:
I understand that this is not within the Fields view, but would this achieve your goal?
KoryKramer
Implemented in ArcGIS Pro 2.7.
See Ideas in ArcGIS Pro 2.7: Something to Celebrate
Also check out what's new in ArcGIS Pro 2.7!
