Users with multiple Portal connections could quickly become confused and run into issues switching to the wrong connection before sharing services. My assumption is that we are all stuck with a long URL and that after adding 3+ we begin to get confused. Please consider allowing users to define an alias for each Portal connection defined in ArcGIS Pro. This simple feature would go a long way to easing the lives of pro users. #esripug
I work for a large multi-national company. Our servers use a non-descript naming convention that makes perfect sense to server support staff, but these mean very little to end-users that might one day be wanting to share local and regional content.
It would be nice to customize your Portal logins in the Project/Portal menu. My current Org is transition from a test to prod environment in Portal. The custom URL's are very similar. It would be nice to give nicknames to them. Also, we use our AD to sync our logins with portal. Although the icons are different colors, the letters inside are my initials are the same as well. Being able to give nicknames or customize the appearance would make switching between Portal environments or different role logins easier and quicker.
Hi @MichaelMcBain,
Thank you for your idea submission. There is an existing idea that might already cover your request: Allow aliases for Portal connections in Pro
Can you please take a look at this to see if it's a duplicate? If so, we can close and merge this idea.
Jonah
This is a great idea. We only have two, but it would be great to give them more meaningful names so that occasional users know which to choose.
I'm going to set this to Needs Clarification @MichaelMcBain as a flag for us to revisit it if we don't hear back from you soon. Please see Jonah's question - it sounds like this may be a duplicate of the existing idea to alias portal connections.
Thank you!
It would be really useful to have the ability of adding an alias to a portal connection under 'Manage Portal' in Pro. If there are quite a few connections, it would be nice to make them more readable; e.g. Production Portal, Pre Production Portal, AGOL.
This would be great! My users don't know what I'm talking about when I say "X portal, Y portal", so being able to just label it for them would be awesome.
I think this could be great as an internal portal setting AND as a user-side setting in Pro. (So like, the portal admin could give the portal a default nickname "State Portal" but the user could nickname it "Nest and Utility Inspections portal" since those are the things that are relevant to them there. Bonus points if both names show up-- again, if I keep calling it the "State Portal" but they don't see anything that says that, it'll get confusing).
