Overwrite a hosted feature layer with views in Pro when the parent hosted feature layer is published from a file in ArcGIS Pro
12283
23
01-06-2022 02:21 AM
Status: Already Offered
ZoevdbAT
When creating a hosted feature layer view the following is stated:
You can overwrite the hosted feature layer from which the view was created to refresh the data only if the following are true:
- The parent hosted feature layer was published from a file in ArcGIS Online, not from ArcGIS Pro or ArcMap.
- The hosted feature layer view was not generated by the Join Features analysis tool.
- You did not define an area of interest on the view.
The first point needs to be looked at. At the moment you can't publish a layer from Pro, make views from the hosted feature layer in ArcGISOnline and then use Pro again to overwrite the hosted feature layer to refresh the data of the parent hosted FL.
When using the overwrite web layer tool in ArcGIS Pro it tries to delete all the related service items. Which it can't because there are views created from the parent layer.
StatusMessage: Server Response: ERROR: code:400, Unable to delete item. This service item has a related Service item, Bad syntax in request.
However you CAN publish from a FGDB (or any other file) in Online or use FME to publish. It really stuns me that you can't use ArcGIS Pro for this.
So please take it into consideration to fix this!
Kind regards,
Zoë
23 Comments
Esad
@KaraUtter I hope the same. Found out that append is available through Python or REST API but if several map services with multiple layers need to be updated, the append gets a bit complicated.
So for a workaround, I wrote a script that:
1 - Creates a temporary file geodatabase,
2 - Exports the data from SDE to the temp FGDB
3 - Publishes the map to AGO.
Hope it gives some idea to whoever looks for a solution with scripting.
NvF
Agreed, this should be corrected. Also, it took me quite a bit of time to figure out that item #1, as noted by the OP, was the reason why all of my symbology/popups refused to update appropriately. Very frustrating for users, ESRI.
JonahLay
Hi everyone,
Thank you for the feedback on this idea. Publishing a layer from Pro, creating a view from the hosted feature layer in ArcGIS Online, then using Pro to overwrite the web layer is a supported workflow that should work.
Since it appears that there may be an issue with overwriting layers with views, can you elaborate on when this issue occurs? What specific steps are you taking? Providing more information will help us determine what needs to be addressed.
Thank you!
MelAlexander
@JonahLay  I'm having this issue as well.
I have data that I am publishing to our enterprise and sharing with a group of other editors. I then make a view layer with editing disabled and share it with a group of viewers.
When I try to overwrite the published layer (either adding rows or adding fields), I get an error and then both the published layer and the view layer will no longer draw on a map. I can delete the view layer, but the original published layer seems to be broken so badly that I cant even delete it anymore, they have to me sequestered to an archive folder.
I'd be happy to screenshare to expedite a fix for this issue.
JonahLay
@MelAlexander Thank you for your comments. Have you reached out to technical support? They may be able to pinpoint the cause of the issue to assist in determining a solution.
BrittanyBurson
Tossing a comment in that it would be helpful to be able to overwrite while also supporting views.
gcGIS
Hosted Feature Service Views/Join views are fantastic - but very problematic when you can't overwrite the base feature service or change the schema.
@JonahLay- can we change this from needing clarification?  It's a known limitation and a valid Idea!
JonahLay
To help us reproduce the issue, it would be great if anyone can provide more information. Specifically, we'd like to know the following:
  • Are you sharing to ArcGIS Online or ArcGIS Enterprise? What version of Pro are you using?
  • When you share the web feature layer, what settings do you configure? (i.e. sync, editing, sharing to groups...)
  • What settings do you enable when creating the view in ArcGIS Online/Enterprise?
  • What changes do you make to the map/layer in Pro before overwriting?
  • Do you make any changes to the view?
Any repro steps you can provide will help us investigate this problem. Thank you.
JonahLay
Thanks to all of you who commented on this idea. As previously mentioned in this thread, this workflow is already supported. If you are experiencing issues overwriting web feature layer with views using ArcGIS Pro, please message me privately so that we can troubleshoot the behavior.
Best,
Jonah
TomNeer
Would it be possible to know what versions of ArcGIS Pro and Enterprise
this is supported at?
