Map series - remember 'Name' and 'Sort' fields when opening Layout Properties > Map Series
548
04-18-2023 01:24 PM
Status: Open
wayfaringrob
Honored Contributor
When opening Layout Properties > Map Series (Layout View > Contents Pane > Map Series > double click header > Map Series), remember the Name and Sort fields previously specified. Right now they default to the first item on the list; if you click Cancel things are fine but if you need to click OK you need to reset your fields first.
Ex. I set both to NAMELSAD and click OK.
The next time I open the Map Series tab, they've reset to STATEFP without my input, and if I click OK, these take effect.
1 Comment
KevinDonahue3
I want to second this idea.  I've been doing a lot of work with map series lately and this can be frustrating on its own and has led to a few bad exports over time.  I've started trying to arrange the fields so the key appears first, but it's an easy trap that I've seen a few others fall into as well.
