Make Query Table — Edit SQL expression in layer properties
320
05-08-2024 09:06 AM
Status: Open
Bud
Esteemed Contributor
ArcGIS Pro 3.3.0; File Geodatabase:
I can use the Make Query Table geoprocessing tool to create a Query Table in a map. I can define a SQL expression in the Make Query Table tool. The SQL expression will be hidden/embedded in the Query Table; it is not a definition query.
Once the Query Table has been created, I can't seem to edit the SQL expression (unless I export  it to a .LYRX, edit the file's JSON text, and re-add the .LYRX to the map).
Could Query Tables be enhanced so that we can edit the SQL expression in the layer Properties > Source tab? Similar to what we can do for Query Layers.
