Layer to KML for Selected Records
5639
8
10-09-2018 07:30 AM
Status: Implemented
by Anonymous User
Not applicable
In Arc GIS pro, when exporting layer to KML it exports all the objects to KML despite we only select few object.
Can this be fixed so that it allows user to export only selected objects if that is what they intend?
8 Comments
KoryKramer
I just did a quick little test and it looks like you can use Make Layer From Selected Features
and then feed that into the Layer to KML tool.  That should do what you need.
by Anonymous User
Kory,
In arc map, if you use KML tool, it allows you to create a KMZ directly from selection without taking an extra step.
I was just wondering if that can be implemented into arcgis pro without creating more features and then having to delete it.
It would be greatly appreciated.
KoryKramer
I just compared and can confirm that the tool honors the selection in ArcMap and not in ArcGIS Pro.  I'm going to check with the geoprocessing team to determine whether this as changed for some reason or see if it is a bug.  Thank you.
KoryKramer
by Anonymous User
Kory, do you know when in the product plan for ArcGIS Pro is this expected? The Bug info (Bug BUG-000122278) is not really specific other than stating that it is in the product plan. We struggle with this regularly (our workflow is to export our subset, import symbology, etc... which is tedious with many layers).
We appreciate your help!
Verità GIS
KoryKramer
Implemented in ArcGIS Pro 2.7.
See Ideas in ArcGIS Pro 2.7: Something to Celebrate.
Also, check out what's new in ArcGIS Pro 2.7!
RobertTaylor5
This still does not work in ArcGIS Pro 3.1.  All features are exported to the KMZ, not just selected features.
KoryKramer
Hi @RobertTaylor5 our team just did a quick test on Pro 3.1.3 and only the selected features are converted. I'd recommend contacting Technical Support to report the case you are seeing. Thank you.
