Geoprocessing: Save custom default parameters
701
04-03-2026 03:13 PM
Status: Open
AlfredBaldenweck
MVP Frequent Contributor
I spent the week using Find Identical  and Union over and over across several projects.
Both of them have settings that I always want to use, but are not the default setting.
For Find Identical, it's "Output only duplicated records".
For Union, it's "Attributes to Join --> All attributes except feature IDs"
Having used both of these tools something like 80 times each this week, I would really prefer to have the option to save certain parameter values as a user-specific default. I think this would be good for any choice value list or boolean parameter. For example, the option to save "Geodesic" as the method in the buffer tool
Or perhaps being able to set a default unit to use in the buffer tool.
This has been a pebble in my shoe for the last week. I recognize that not everyone has the same needs or preferences as I do, but I'm sure they'd like being able to save their own preferences.
4 Comments
Bud
Good idea.
This idea is different, but related:
Import/export native GP tool parameters to file
JesseWickizer
When I need to frequently run the same tool (or sequence of tools) with mostly the same parameters each time, I use ModelBuilder to create a model with the tool(s) and pre-fill the parameters that don't change between successive runs, and hide parameters that I don't change and don't need to see. That way I only have to change the necessary parameters each time and the rest are already saved. Here's an example a custom model containing only the Find Identical tool with some of the parameters hidden and some pre-filled:
MargaretCrawford
Hi, you can override default parameter values using a Pro.settingsConfig file. I detailed some steps on how to do it in this blog:
https://www.esri.com/arcgis-blog/products/arcgis-pro/analytics/tool-parameter-overrides-in-arcgis-pr...
AlfredBaldenweck
Hi @MargaretCrawford , thanks for the response.
I'm a member of an organization that uses the Pro.settingsConfig file to manage certain settings across all the members.
Is it possible for me to reliably edit that and still have it take effect?
1) Will it work?
2) Will it get overwritten the next time they alter our configuration?
If the answer to either of those questions is No, then I think there's still a need to be able to save things like this at a personal level through user.config/the Pro GUI.
