Geoprocessing Environments: Make Snap Raster as Default to Preserve Cell Alignment
1375
04-06-2022 04:44 PM
Status: Open
AndrewLintz
Problem: GP Raster tools output rasters offset by a cell/pixel from input.
Example of Problem: The attached screenshot is what happens if a snap raster is not set.
Current Work Around: in Global/Geoprocessing environments/model GP Env settings you can define the snap raster.
Example of Current Work AroundTo correct the problem, I selected the DEM_10ft_SV as the snap raster. That means if I run this series of gp tools again, the outputs will snap the upper left corner of the output rasters to the DEM cells. (DEM = Digital Elevation Model)
Ideal Solution: Make it DEFAULT to snap to input raster, with the option to define to not snap.
