Export Layout to Project Folder
13289
25
02-02-2021 07:11 AM
Status: Implemented
LeoLadefian3
Currently ArcGIS Pro default export location is the last place something was exported to globally.  This should be set to the last place something was exported to for each project, similar to ArcMap. The default should be the project folder.
25 Comments
AubriOtis
This is implemented in ArcGIS Pro 3.4. Go to Your Ideas in ArcGIS Pro 3.4 to see other ideas implemented this release and check out the What's New help to learn about everything that is new and improved in ArcGIS Pro 3.4.
RichardHowe
When setting the export path whilst exporting a layout ArcGIS Pro's default behaviour seems to be to want to default to the last location you created an export to from any other .aprx
This is strange behaviour and cumbersome, for those of us who work with lots of different aprxs on a regular basis - having to manually re-navigate to the default folder associated with the aprx. The fact that a default folder can be set in the project should mean that location becomes the default export location for layouts, in the same way a default geodatabase becomes the default export location for data.
DanPatterson
something along those lines was implemented in 3.4
if it isn't the same as your suggestion, then have a look through the long thread
Export Layout to Project Folder - Page 3 - Esri Community
RichardHowe
Thanks @DanPatterson . Hadn't spotted that (and haven't upgraded just yet) but it seems like that will hopefully do the job. I knew it couldn't just be me 😂
