You mention Export Layer Style but I don't see a command for that in ArcMap. I see Export Map Styles
Is that the command you're referring to? If so, this is a duplicate of https://community.esri.com/t5/arcgis-pro-ideas/arcgis-pro-quot-export-map-styles-quot-for-bulk/idi-p...
Please let us know!
@AriLukas can you see my Needs Clarification comment from above and let us know if the Export Map Styles is what you're referring to? Thanks
Closing this pending further clarification. It sounds like this is a duplicate of https://community.esri.com/t5/arcgis-pro-ideas/arcgis-pro-quot-export-map-styles-quot-for-bulk/idi-p...
This new functionality in ArcGIS Pro 3.2 allows users to save a style file and export only any classes within a layer, with the same name as the layer itself. This feature eliminates confusion and won't helps users to reuse symbols with the actual names of their respective class/subtype. Exporting classes with the same name of layer is unhelpful. Anyone try this update of Save a style file?
Below in my example all the subtypes' classes have been exported with the same layer name:
