Export layer style
1972
07-14-2022 09:53 AM
Status: Closed
AriLukas
It would save a ton of time if the Export Layer Style that exists in ArcMap was included in Pro
Tags (1)
5 Comments
jcarlson
What does that look like in ArcMap? I've never used it, but in Pro there are numerous ways to save the way a layer is styled.
KoryKramer
You mention Export Layer Style but I don't see a command for that in ArcMap. I see Export Map Styles
Is that the command you're referring to? If so, this is a duplicate of https://community.esri.com/t5/arcgis-pro-ideas/arcgis-pro-quot-export-map-styles-quot-for-bulk/idi-p...
Please let us know!
KoryKramer
@AriLukas can you see my Needs Clarification comment from above and let us know if the Export Map Styles is what you're referring to? Thanks
KoryKramer
Status changed to: Closed
Closing this pending further clarification. It sounds like this is a duplicate of https://community.esri.com/t5/arcgis-pro-ideas/arcgis-pro-quot-export-map-styles-quot-for-bulk/idi-p...
Mai_Ghaly_Gazar
This new functionality in ArcGIS Pro 3.2 allows users to save a style file and export only any classes within a layer, with the same name as the layer itself. This feature eliminates confusion and won't helps users to reuse symbols with the actual names of their respective class/subtype. Exporting classes with the same name of layer is unhelpful. Anyone try this update of Save a style file?
Below in my example all the subtypes' classes have been exported with the same layer name:
