Error Inspector Filter: select multiple Layer - Rule
338
10-17-2022 03:08 PM
Status: Open
BibiOung
New Contributor II
Kindly, add the ability to select more than one layer and rule under Error Inspector Filter (Rules).  At the moment, one could only select Show error for all errors or select one rule at a time verses the ability to select multiple rules.   For example: one is allowed to select one rule, ParcelLines - Must Not Self- Overlap - Parcel_Lines verses multiple rules, ParcelLines - Must Not Self-Overlap, ParcelLines - Endpoint Must be covered by - Points, Parcel_Lines Must Not Have Dangles - Parcel_Lines, etc.
This is very helpful as one department maintains Parcels while another department maintains Lot, Subd, etc.  This is critical to an upcoming successful implementation to PF.
Also, it would be helpful to have the ability to sort Feature 1, Rule, Feature 2 and Exception column.
Thank you.
