Dynamic image in layout (not map series)
1611
10-24-2022 02:26 PM
Status: Under Consideration
CA_SC_-_EricBall__GISS_
Please add a dynamic image to layout (that is not a map series)
I work GIS on wildland fires. Generally on a large fire, multiple teams are required over the extent of the incident. Every couple weeks a new management team takes over and with the new team comes a new team logo that is attached to all of the maps. We often have 15 or so maps, each with its own project and some with multiple layouts depending on the needed print size.
It would be great to have the option for dynamic images in layouts (not sure why they are only allowed in a map series). That way when the new team comes in, we can just switch out the logo image itself (in the logos folder) or change a dynamic set path once and all the maps would show the new logo. Right now, while the image property points to the image file location on the computer or URL, the image is cached on the project and is not actually dynamic. So each project and each layout has to be opened and a new logo added or repointed.
It's an unnecessary time suck.
Tags (4)
3 Comments
I ended up writing a python tool that will reload the image or change it to a new one. It can target all layouts or a targeted one (by name) within all projects within a folder.  Then you can either refresh the logo or replace it with a new one (based on layer name of logo).  It works, but I a new to this but an actual dynamic link would be much better.
AubriOtis
JasonBennett
This would be very useful for me. only about 20% of the layouts I make a map series and I have to swap out images for each one.
