duplicate layout
9511
18
09-15-2021 01:07 PM
Status: Implemented
MarcelSt-Germain
In catalog be able to duplicate a layout.  So add a duplicate item in the right button menu to do so.  Now you can only copy and paste.  The problem is that it's also duplicate the maps.
We just need a copy of the layout with all layout elements being the same, same map it's pointing to, scale, etc..
For now very time consuming to change everything and delete these unwanted maps.
18 Comments
KoryKramer
To clarify the status of the bug see https://support.esri.com/en/bugs/nimbus/QlVHLTAwMDE0NDMzMg== which indicates this is fixed in ArcGIS Pro 3.0 which is due to release in 1 week - June 23rd.
(Sorry about the display issue with the actual Status on the support site. That is an issue they are looking to get fixed.)
Jimmy_Simpson
@KoryKramer  Well dang, I wish they wouldn't have fixed that bug until they added a way to duplicate the map with the layout. I'm going to miss this bug.
KoryKramer
🙂 Yep, what is a bug to one may not be a bug to all...
StephenSkartvedt
I’d also be interested in duplicate layout functionality.  For now I am using SDK sample code to add “Clone Layout” on right click mouse menu (easy to add - no coding required).
I’d like to also request this functionality via Arcpy.  We have series of projects that follow pattern of    matching layouts to groups of feature classes. All is automated except this last step of creating layouts 1-> n.   This step is time consuming even with the clone command.
KoryKramer
@Jimmy_Simpson see https://community.esri.com/t5/arcgis-pro-ideas/duplicate-both-layout-and-associated-maps/idi-p/11368...
Thank you for the comment @StephenSkartvedt  I took a look and it doesn't appear that you added your kudos to the idea. While comments are important, kudos (the number of votes) that an idea receives is one of the primary pieces of data that we use to determine traction and trends as we monitor idea activity over time.
Please see https://community.esri.com/t5/custom/page/page-id/arcgis-ideas for a high level overview of how ArcGIS Ideas works. For more details, see Frequently Asked Questions about ArcGIS Ideas
Thank you for your participation in the community and for helping us prioritize future development efforts for ArcGIS Pro.
NaicongLi
wayfaringrob
Right now to duplicate/resize a layout you must first open it, click the layout tab, and then click Duplicate Layout. It would help me work more efficiently if Duplicate Layout were a context menu option in the catalog view & pane.
KoryKramer
This Idea has been implemented in ArcGIS Pro 3.2. Please see the What's New documentation for more new features in Pro 3.2.
The Your Ideas in ArcGIS Pro 3.2 blog and video have been posted to the Esri Community blog. You can take a look at these to see your idea and all others that were implemented in this release of ArcGIS Pro.
