Draw geospatial objects in several layers simultaneously.
1423
11-07-2024 06:21 AM
Status: Already Offered
FedirBalaba
For example, you have a polyline layer with a sewer pipe and a point layer with a manhole. You want to be able to draw a polyline of a pipe with a manhole at the end, or at the beginning and end, or manholes at a certain interval in meters in one operation.
4 Comments
AlfredBaldenweck
LauraGosnold
I  use the snapping tool to snap my polylines to points.
In our case, the manholes have been gps'ed, so I know drawing in sewer or water lines from one hand hole or manhole to another opening in the line is accurate.
Hope that helps.
FedirBalaba
I vectorize utility networks using raster data from topographic and geodetic surveys by comparing the actual location of manhole covers on a high-resolution orthophoto. I've seen a similar drawing function in AutoCAD and would like to implement it in ArcGIS as my main software.2024-11-08_083931.jpg
Scott_Harris
@FedirBalaba Like @AlfredBaldenweck mentioned, you can already do this with Group Templates.
https://pro.arcgis.com/en/pro-app/latest/help/editing/create-a-group-template.htm
Here is how to create a basic one - but they can get more complex by adding multiple builders:
They also work with a Utility Network:
https://pro.arcgis.com/en/pro-app/latest/help/editing/utility-network-reference-for-editing.htm#ESRI...
