Double-click feature to edit vertices
1352
02-12-2025 11:37 PM
Status: Open
Bud
Legendary Contributor
Steps:
  • Create a polygon using the Create Features pane.
  • Clear the selection.
  • Using the select tool, double-click the polygon I created (or an adjacent polygon) to edit the features. Double-clicking has no effect.
Idea: Instead of navigating to the Modify Features pane and clicking Edit Vertices, I want to use the select tool to double-click a feature to edit the vertices.
Video:
(view in My Videos)
5 Comments
JMutunga
@Bud  not quite what you are looking for but you can access Edit Vertices from the right-click menu. Depending on your cursor location on the map, accessibg the tool from here could reduce mouse travel to the Edit ribbon's tool's Gallery.
Bud
@JMutunga Thanks.
CortWilson
Double-click to edit vertices was stolen from us in ArcGIS Pro! 🙂  We want it baaack. A very simple shortcut to help streamline editing workflows. When a feature is selected in ArcGIS Pro, double-clicking that feature literally does nothing; replace nothing with something helpful!
@KoryKramer
NateFears
Yes, as Cort Wilson and Bud said, please add back to ArcGIS Pro the shortcut of enabling the 'Edit Vertices' tool by double clicking a feature.
Thanks
-_-
@JMutunga
The use of right-click has issues, as discussed in the following topics:
https://community.esri.com/t5/arcgis-pro-ideas/way-to-disable-and-or-change-the-quot-right-click/idi...
https://community.esri.com/t5/arcgis-pro-ideas/when-editing-prevent-zoom-when-right-clicking-on/idi-...
This issue still exists in version 3.6. I would like to be able to edit vertices without right-clicking again.
