Create Feature Class wizard: get to 'Import' button with keyboard more easily
410
12-15-2022 02:30 PM
Status: Already Offered
wayfaringrob
Honored Contributor
See below video - when using the keyboard (tab/shift-tab/space) to navigate the Create Feature Class wizard, allow the user to access the 'Import' button. Tabbing stops at the table headers unless you tab all the way down and back up, which actually crashed the application the first time I did it.
4 Comments
SSWoodward
Thanks for the idea @wayfaringrob.
When using only the tab key to navigate through the fields page of the feature class wizard, the focus will move from the Next button that is initially selected, across the bottom of the page, and then work its way from the top down.  This will move the focus through the page selectors, followed immediately by the import button. Navigating this way allows you access to the Import button before the focus moves to any of the field headers. I've included a GIF below.  Are you seeing a different behavior in your current version of ArcGIS Pro?
wayfaringrob
@SSWoodward  yes, per the video, it seems something in the table is first active -- I don't have to tab through the dots nor does the Import button become active. Version 3.0.3.
SSWoodward
Thank you for clarifying, @wayfaringrob .
I've tested this in 3.0 and 3.1 beta and unfortunately, I am unable to reproduce the behavior that you are experiencing. Navigating through the wizard with the tab key has consistently behaved in the way depicted in the GIF I shared above. Because of the nature of the issue, I feel the best answer as to why the behavior is occurring would come from one of our Support Services Analysts who would be able to gather additional context around the issue.   You can reach our Support Services department at 1-888-377-4575, Monday–Friday, 5:00 a.m.–5:00 p.m. PST, or http://support.esri.com/contact-tech-support.
SSWoodward
