Smart Forms/Conditional visibility in Attribute View and in Create Features
2392
02-28-2024 06:30 AM
Status: Under Consideration
SimonSchütte_ct
MVP Regular Contributor
In Field Maps, we can use conditional visibility to streamline data collection.
The same functionality would be welcome in ArcGIS Pro for editing.
Ideally Field Maps and ArcGIS Pro conditional visibility is compatible.
Author smart forms in ArcGIS Pro for direct use or for publishing to with MapViewer/FieldMaps.
Example use:
-> Select a domain value -> depending on the selected domain value, only show the fields relevant for this domain. Hide the other fields in the "Attribute" view and in "Create Features"
Drag and drop and conditional visibility and values based on arcade as it is possible in Field Maps: Forms aren’t just for ArcGIS Field Maps anymore (esri.com)
Related questions: Can fields be made conditionally visible when edit... - Esri Community
Using smart forms in Pro? - Esri Community
4 Comments
JMutunga
Thanks @SimonSchütte_ct  for posting this idea. I have updated the status and left the idea open for other members to upvote.
TomTanyBryn
The ability to create smart forms in Pro would be really useful.
ClintSteeves1
100% agree with this. Needing to recreate my forms in Field Maps every time I need to make changes to my data in Pro is a huge source of wasted time. The functionality of the smart forms in Field Maps is awesome, and is always improving. Let's get Pro set up to be able to do the same thing.
SimonSchütte_ct
Mid-term (next two or three releases) ArcGIS Pro Roadmap - November 2025
Support for Attribute Editing Forms - The first phase of this project will provide support in ArcGIS Pro to use attribute editing forms created in other ArcGIS applications (Map Viewer and Field Maps Designer). The second phase will provide support for building and configuring forms from ArcGIS Pro.
/ will not be in 3.7. Maybe in 3.8
