Catalog view - rename a feature class (while previewing table)
2628
7
07-10-2024 12:16 PM
Status: Implemented
wayfaringrob
Honored Contributor
Yet another operation that should be simple in ArcGIS Pro, but it's not. If you go to rename a feature class you are viewing in the catalog view, you face an issue. Upon a second click on the feature class (aka "soft click" or "slow click"), which normally enables renaming, the table preview reloads itself and renaming is disabled, returning you to the selection and table preview below.
Not an issue in ArcCatalog at all, which still does not have a Pro equivalent ( Offer a standalone ArcCatalog replacement for ArcG... - Esri Community ).
7 Comments
SSWoodward
Thanks for this Idea @wayfaringrob,
I see two different behaviors when I attempt to reproduce this.  If the 'Metadata' tab of the catalog view has the focus, the cursor allowing renaming is activated on the second click.  If the 'Table' tab has focus, then the second click temporarily activates the cursor, but it is quickly closed and I am no longer able to rename.
Is that also the behavior you are seeing? I am in ArcGIS Pro 3.3.  Is that the client version you are also in?
wayfaringrob
@SSWoodward  Yes, seeing the issue with table (my most used) tab, not the others
3.3.1
SSWoodward
Status changed to: Open
SSWoodward
Thank you for clarifying.  I will ensure that gets viewed by the correct team.
NaicongLi
NaicongLi
KoryKramer
This is implemented in ArcGIS Pro 3.4. Go to Your Ideas in ArcGIS Pro 3.4 to see other ideas implemented this release and check out the What's New help to learn about everything that is new and improved in ArcGIS Pro 3.4.
