Catalog — CTRL + double-click to Open Table
1119
04-24-2023 05:40 PM
Status: Open
Bud
Legendary Contributor
ArcGIS Pro 3.1.1
In the Catalog pane, it would be helpful if we could CTRL + double-click to open the table of an item (item not added to the Contents pane).
It would be the same functionality as right-click —> Open Table in Catalog.
Similar to what we can do with items that are added to the Contents pane.
2 Comments
Bud
This idea is listed in the Your Ideas in ArcGIS Pro 3.2 post (under Data Management —> Content Management).
However, as far as I can tell, this functionality still isn't available in ArcGIS Pro 3.2. CTRL + double-clicking a standalone table in the Catalog pane has no effect.
KoryKramer
Hi @Bud
With the release of ArcGIS Pro 3.2, you now have a keyboard shortcut for opening a table: Ctrl+Shift+T.  (The keyboard shortcuts available for Catalog pane and Catalog view are listed here: https://pro.arcgis.com/en/pro-app/latest/get-started/arcgis-pro-keyboard-shortcuts.htm#ESRI_SECTION1...).  Furthermore, If you prefer to use a different keyboard shortcut for opening a table, you can change it in the Keyboard Shortcuts dialog (please see https://pro.arcgis.com/en/pro-app/latest/get-started/manage-keyboard-shortcuts.htm#ESRI_SECTION1_505...
We chose the keyboard shortcut of Ctrl+Shft+T to correspond with the alternate Ctrl+T shortcut that is available in map views to open a layer's attribute table. We did not use the double-click version of the same shortcut because of possible conflicts with other operations in the Catalog pane and Catalog view and a requirement to satisfy keyboard-specific usability requirements.
Thank you for your feedback. Hopefully this explanation is helpful. I removed the hyperlink from the blog that you referenced and this idea will remain Open.
