Calculate Value in ModelBuilder - Vertically expand expression textbox (to multi-line textbox)
474
02-14-2024 10:07 AM
Status: Open
Bud
Honored Contributor
In the Field Calculator window:
As mentioned by @Anne-MarieDubois, it would help if we could vertically resize the Expression section to view/enter lengthy expressions.
Source: Expression Builder: Vertically resize sections
I'm aware that I can widen the entire window to view more of the Expression text. But at a certain point, I just want to make the expression parameter taller, not the window excessively wide.
Tags (1)
4 Comments
MErikReedAugusta
The same is true of the Code Block (though if memory serves, there's already an Idea for that).
I couldn't being to tell you how many times I've needed less space for the Variables (which I often know by heart) and the Functions (which I almost never use from there) and more space for me to freely write my own Expression & Code Block.
I recognize I'm maybe not a typical user in that sense, but that's just all the more reason to make these three groups/rows of input resizable.
DrewFlater
The Calculate Field expression control already grows up to 5 lines to show longer expressions.
@Anne-MarieDubois  comment on the other issue is about Calculate Value which is a ModelBuilder utility tool. I can confirm that the Calc Value expression control does not exhibit the same growing behavior.
Anne-MarieDubois
Hi @DrewFlater ,
This doesn't seem to be an option for me.
No matter how long my expression is, I can't expand  the box.
Could this be linked to the latest patched not being installed?
DrewFlater
Status changed to: Open
