Cache PDF Metadata from previous export
1676
03-24-2023 10:56 AM
Status: Already Offered
AmyRoust
In ArcGIS Pro, you have the option to add metadata and accessibility tags to a PDF export. It would be lovely if the information that you enter the first time you export a PDF is somehow cached so that it will automatically be populated when you need to export it again in the future.
Using screenshots to explain, here is what I filled out for my PDF export the first time:
If I need to make a minor change to the layout and then export it again, this is what the Accessibility tab shows:
I'm not sure what would be involved with caching the metadata, but at the very least, it would be nice to have the option to check "Include accessibility tags" by default.
4 Comments
EdwinNieuwland1
yes or better read it from the layout metadata
AubriOtis
Just an update, as of ArcGIS Pro 3.1 the include accessibility tags checkbox is on by default.
BrettFrahm
@EdwinNieuwland1
@AmyRoust
I have created an idea asking for the pdf metadata to be sourced from the layout properties metadata here (https://community.esri.com/t5/arcgis-pro-ideas/source-pdf-metadata-from-layout-metadata/idi-p/165804...) if you'd like to check it out and add your support.
AubriOtis
This is available with export presets in later versions of ArcGIS Pro 3.x
