Bring Back Multiple Data Source Repair "Repair Data Source"
1559
05-20-2025 12:23 PM
Status: Already Offered
nheg
I searched the community and this problem still doesn't seem to have a REAL solution, just a poor tedious one and so I am submitting it here:  ArcGIS Pro still needs a way to fix multiple paths to data files, shapefiles, or GDB all at once.  For example, for lost file connections in ArcMap (red !) I could simply right click, select Data, then "Repair Data Source" and if I repaired the path to one data set in a folder it automatically corrected all the other broken links to that folder, essentially fixing 5-10 broken paths all at once!  But in Pro, when I right click, select Data,  all I see is “Set Data Source” which only repairs one path at a time (just like it did in ArcMap =  "Set Data Source" fixed one at a time, while "Repair Data Source" fix all at once) and so I have to do this 5-10 times to repair all the broken links.  There should be a faster way to do this? Why did ESRI remove“repair data source” to fix all the broken links to a single folder or GDB all at once?  BTW it needs to repair links to shapefiles as well as GDB because many of the people I assist don't understand or need GDB and still work with lots of shapefiles.
3 Comments
AlfredBaldenweck
That is still a largely viable workflow?
Just hit the red exclamation point on the broken layer and proceed as normal.
That being said, this method is not 100% Repairing Data sources with Exclamation point: Rep... - Esri Community
But by and large, the exact same behaviour is maintained except you don't right-click.
nheg
Okay, I didn't understand, I read that as right-click red !.  In any case I re-read 3 times and now understand to just Click once on red ! and that worked.  Who would have thought?  Thank you!!!!
I am adding more here for people like me to see the solution more easily... Click red ! once and that acts like the old ArcMap "Repair Data Source" (repairs multiple paths to same folder at once), while right-clicking the Red ! & selecting "Set Data Source" only repairs one file path at a time.
ValeriaChavez
Hi @nheg! Closing this as already offered based on the workflow shared by @AlfredBaldenweck. Thanks 🙂
