When building a definition query in ArcGIS Pro, the auto-complete functionality should use the descriptions from the coded value domain for the selected field (assuming the field has a coded value domain applied to it). Having the list pop-up for the domain values is helpful, but being able to type the first few characters of a description rather than having to scroll through the entire list would be much better (of course behind the scenes the real value would still be used for the actual definition query, this would just make building that query easier). Currently the auto-complete functionality works if you start to type the code, however often the code isn't a known value, but the description (or part of it) is.
