Auto Re-Numbering "from" and "to" points
347
09-13-2016 03:43 PM
Status: Closed
ByronJohnson
When you open an un-joined parcel in parcel explorer to edit, specifically to add courses to the parcel. You can insert a new row for any additional courses you wish to add in the parcel details window. However when you accomplish this the "from" and "to" points have to be renumbered manually. This becomes somewhat of an intensive edit process when you have many courses (50, 100 or more) in the parcel. Especially when you may be editing and adding courses at say course number 12 or 30 and you may have a total number of 100 courses. In the time it takes to re-number the courses you could probably just re-enter the entire set of courses to get the sequential course numbering that is more desirable. The problem with re-entering the entire set of courses, it is time consuming and could also result in input error by missing a course (this has happened to me, we never get interruptions while working, not). It would be extremely helpful if there was a means to select auto renumber for the "from" and "to" points after editing and adding or deleting courses (same problem).
Tags (1)
2 Comments
ByronJohnson
I found a temporary solution for auto re-numbering in parcel explorer. It will not allow any non-sequential numbers to be inserted in the from and to columns in the parcel details window. However it will allow say you are adding a new course from 17 to a new to, it will allow the use of 171 and then 171 to 18. Once you complete your edits the parcel will indicate a break in the polygon. Just save your edits as un-joined and the un-joined parcel will renumber starting with "one" all courses sequentially for the polygon. Then you can join it back to your data.
KoryKramer
Status changed to: Closed
Closing this idea as it refers to the ArcMap Parcel Fabric and is not relevant to ArcGIS Pro.
