I've run into a few workloads (such as documentation and updating symbols in ArcGIS Online) where I need to save a point symbol created in Pro to an image. I can do this by hand using image editors and print screen with the symbol preview window but this is more time consuming and error prone than if I could export the symbol directly to an image file (PNG, GIF, BMP etc.). This could also allow me to render the symbol at very high resolutions for archiving purposes and avoid issues with removing the background color from the screen capture. A SVG export option for supported symbols would also be nice but exporting to a raster image format would work for me.
@MapMan1You're a genius! That worked perfectly!
